How to place a Section in Sketcher Mode 2000I2
Hi you all,
I am having difficulty placing existing
section in sketcher 2000I2. I have lots of section
already drawn in Autocad, and would like to use them
in Pro_E 2000I2 Sketcher Mode.
Is there an easy way to do this? Please
give me some steps that I can follow thru.
Thank You so much for your effort............
Have a happy, healthy, and a prosperous New Year....
Navin P
Navin P
RE: How to place a Section in Sketcher Mode 2000I2
I can not remember exactly how to do this in 2000i2 as it has changed in 2001 but I think you get to it by file,append to file.
I know it can be done but I have found that dxf files work the best from Autocad however check the dimensions of the imported section.
Good luck.
file, import, append to model.
now you'll see files of type .sec and you can place them.
