drilling steel pipe - help please !
Tomorrow I need to drill approx 20 x 2 1/2" (63mm) diameter holes through the side of a 18" diameter steel pipe.
The holes are to take pins. I have thought of two ways to do this -
a) magnetic base type clamp on drill with a 2 1/2" cutter.
this would be the ideal way but the pipe grade is x52 steel , i think it will be to tough for the drill at that large diameter. steel thickness is 7/8"
or b) flame cut the holes and weld in machined bushes. A bit more work by the sounds of it having to machine all the bushes.
any ideas on how heavy going it would be drilling it?
i once drilled similar sized holes through 1/2" sa 516-70 and it bluntened the new cutter immediately. i dont think x52 is quite as tough as boiler steel though.
any help would be very gratefully received. thanks neville
RE: drilling steel pipe - help please !
Precision flame cutting with a jig is possible with everything thing depending on type hole and the precision needed.
htt
You can rent these machines and just purchase the cutters.
The pilot hole can be something like 1/2 diameter, center punch the pipe OD at the desired location. This will ensure the drill doesn't skip, wander off location.
Just a thought.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
I know x52 is a high yield, perhaps not as high as 516-70 boiler plate, but i am concerned that i could waste over $1000 of cutters and a lot of time. we are doing the job outside so dont have a radial drill, that would have been ideal!
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Mike Halloran
Pembroke Pines, FL, USA
Cory
http://www.phalco.com/mirageMachines.htm
Here is the company that makes the tools that Phalco has.
Look at model DD1632
http://www.mirage-machines.co.uk/drills.htm
So what was your final solution? How did it work?
