Block within a block within a block ...
Is it possible ??
Sorry to ask, but I tried to do search and could not find anything (perhaps it's me not knowing how to do it well  sad  )
RE: Block within a block within a block ...
what type of block? Can you explain more?
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
[quote]... Can you explain more? [/qoute]
Purely "dwg block".  Let's say on dwg you have a rectangle and a text inside of it. You make a "Block1".
Then another rectangle and a different text inside. You make "Block2".
Now, can I make "Block3" having inside of it "Block1" and "Block2" AS BLOCKS.
So far I can make "Block3" but inside of Block3 the components (Block1 and Block2) get exploded. I would like to have keep as blocks.
Just started to read Help - Group Annotations.  Could that be it ?
As far as I know, you still need to explode them. I have not been able to use a block within a block. I don't have SW06 yet, maybe it has changed?
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
