Expansion Joints in Steel Roof Deck
Does anybody out there have any practical guides for determining whether an expansion joint is necessary/required for a bar joist and steel deck roof? My building in question is 172' wide x 304' long. Intuition tells me that something may be warranted here, but I'm not sure.
Any help with this would be greatly appreciated!
RE: Expansion Joints in Steel Roof Deck
Its says you can read it for free. Actually once you get into it you can print a version of it. Good luck
Consideration should be made for expansion joints depending upon whether the finished structure is subject
to wide swings in temperature (which you did not mention) or whether it is heated/cooled. Also the location of bracing can have an effect. For instance if the bracing is centered, the structure will grow each way from the bracing, however, if it is located at one end, then the expansion affect will be doubled.
I hope this helps!
