Audio File Question
Audio File Question
I just started writing a program that will graph different features of sound waves. At this point I've only writen code to graph the raw data from a uncompressed 16 bit wav file. The graph looks perfect and exactly how I would expect a sound wave to look but for some reason the zero point of the waves is above zero.
I had sort of assumed that when a computer records a 16 bit wav file that zero would represent no pressure change, positive numbers would represent when the pressure incresed above the normal pressure on the cresting side of the sound wave and negative numbers would represent when the pressure decreases below normal pressure. So I sort of expected the total of all the numbers (except for the header) in a wav file to be roughly zero.
So my question is, did I make an incorrect assumption or did I possibly program something wrong?
thank you for your help.
RE: Audio File Question
Say, wouldn't it be pretty easy to record a small WAV file
without an input, then run it through your program and
see what pops out on the graph?
At first blush, and I could be absolutely dead wrong, I see no reason for having an "AC coupled" source not have a representation of zero or 1/2 full scale. However, and here's another area where I could be dead wrong, the modulation scheme used might be something like a "delta" modulation, where indeed, one would expect a "positive" differential of the waveform would be represented with an increasing or "positive" representation while a "negative" differential of the waveform would be represented with a negative representation.
Since it's in a "digital" form, there are all kinds of modulation schemes, and data compression techniques that might make the data representation unclear. O.K a tad looksee via google says that .wav files are PCM modulation.
That means Pulse Code Modulation.
Here's a pretty good little link that I found during the google search that might help explain it. Search for the data string "pcm" and you should run across it in the section titled:
"Sample Points and Sample Frames"
The link is:
http://www.borg.com/~jglatt/tech/wave.htm
Hope that this helps.
Cheers,
Rich S.
I have been dabbling at writing some programs to analyze WAV files too, so it's gratifying to see a post from someone with the same interest. Here is a quote from a site I used as a reference:
The site URL is http
So it would appear your assumption is correct, in 16 bit WAV files the samples are positive and negative. You don't mention if the files you are graphing are mono or stereo. Could this be a factor? I can't speak authoritatively about different sounds cards, but my impression is that most use 10 or 12 bit A/D converters so the samples are not really 16 bits. The sound card driver would determine whether the samples are sign-extended into 16 bits, so this could have a bearing on the numbers. I found it helpful to use a program to dump the contents of files to the display in hexadecimal so I can see the actual numbers in the DATA chunks of WAV files. Hope this helps.
Good Luck,
Greg Hansen
Greg it is nice too see your interested in the same thing. What type of application are you writing a sound analyzing program for?
thanks
Mike
Thanks for the reply post, and your interest. Besides enjoying(?) the challenge of Windows programming, I am an amateur musician. I also have an interest in digital signal processing. Combining these interests (programming, music and DSP) has led me to try to develop an application that would help me figure out the notes being played in a given piece of music, using the raw WAV file data. This is not an especially original objective, and the project has been dragging on for a long time. I have read some material on this type of analysis suggesting that the naive approach I am using, which is to simply use a discrete Fourier transform of the the sampled sound, is useless. Nonetheless, I figured I would start with that objective and see if leads anywhere. And it is a useful learning project, with modest enough goals so that I can maintain (sort of) my motivation to keep at it.
If you don't mind me asking, what is your application?
Good Luck,
Greg Hansen
here is another amateur musician that has been trying to convert a WAV file into music sheets for a long time. I abandoned Fourier transforms too because a simple simulation showed me that it would not work in case of polyphonic tracks. At the moment I do not have any idea what to do next.
m777182
I'm afraid, unfortunately, I don't have much insight to share that would point you in the right direction. My main thought was that I might be able to decode some blinding fast Eddie Van Halen solo or such, based on the idea that the loudest instrument masks the others and would contain most of the signal power. From what I have read, this is one of the priciples employed in audio file compression. I thought it might work in this application too, but perhaps not.
The site I referenced in my previous post, from the Stanford U. Center for Computer Research in Music and Acoustics, seems to be a fairly comprehensive resource on the subject. Have you looked there?
Good Luck,
Greg Hansen
TTFN
I'm writing a sound analyzing program because I have some ideas about how to write some artificial intelligence programs and I want to see if I can write a speech recognition program that actually works well. But before I do that I want to graph certain features of sound files to make certain I'm using the best approach for this. I know there are spectrogram programs out there, but there are certain things I want to look at that they aren't good at.
m777182 I wish I had a good suggestion on how to recognize musical notes but I haven't even looked at what makes a sound sound on-key or off-key or any of that stuff. I've only looked at human speech. The only thing I would suggest is to download a spectrogram program if you haven't already and try to find patterns in musical notes that your program can analyze. Also if you are trying to analyze singing it might help to look at these human speech pages:
http://spe
ht
It might be a while but when I'm done with the graphing program I could give you guys a copy. I don't think I'm going to try to sell it so be warned it probably won't look like a nice polished program.
good luck,
Mike
I have made a small step in my endeavours to transcribe Wave files into music sheets. The clue is perhaps the wavelet transformation of may wave file. I do not need to look for ALL frequencies because beyond 16kHZ we normally do not hear and the lowest time interval is about one quarter or perhaps one eight of the measure. So the time slices of one quarter lenght in time domain would be the samples that are statisticaly stationar and over this time range you perform FFTs. Again you are not interested for ALL frequencies but only for those that are near to the "in tune" frequencies. So we look for spectral lines that correspond to elements of the tonal system. I am making further experiments.
regards
m777182
Dan - Owner
http://www.Hi-TecDesigns.com
m777182
So finding the right wavelet to apply might help in finding the particular tones you're interested in.
