Importing Solid Model into Solidworks
I have to import a solid model from Unigraphics into Solidworks, so I can run Cosmos on it. What do I import it in as, or can it even be done?
RE: Importing Solid Model into Solidworks
YOu should export the model from Unigraphics as a parasolid.  When you open it in SolidWorks you can save it as a SLDPRT.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I agree w/ MadMango.  Parasolid is the best way.  Since UG and SW have the parasolid kernel, no geometry is lost or mistranslated.
SW can open native UG, but this can get messy.  I don't like it.
I agree with the others. I also have opened native UG in SW and it created surfaces shooting out from the part. I was better off re-creating. Parasolids works best.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I've opened native UG files a number times with no problems. Some older UG files come in empty though. I would try that first, then the parasolid option if that isn't working.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP3.3 on WinXP SP2
I think the parasolid would be the best route since you plan to use COSMOS.  That way you don't have to knit surfaces together and spend time fixing the model...at that point it's almost worth building it within SWx.
I do a lot of file transfer between Pro/E and SWx and Pro/E and CATIA.  When time allows me I just rebuild the model that way I have the ability to optimize the geometry when in COSMOS or CAMWorks.....just something to consider.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
