Ansys 8.0 - Error in startup script
I have installed Ansys 8.0, but whem I try to start the package I get an error saying: 'Error in startup script, can't find package Itcl, when executing, "package require Itcl"'
IK happens when i try to start ANSYSED or configure ANSYSED. The cd worked fine on another PC. Anybody know the awnser to this problem?
RE: Ansys 8.0 - Error in startup script
I have the answer to your problem ... I had the same one and here is the solution:
'Error in start up script'
'can't find package Itcl while executing
(file "c:\documents and settings\user\program files\ansys inc\v##\commonfiles\launcher\launchermain.itcl" line41.
Add the following lines to the paths and the launcher will run. Please note that the TCL_LIBRARY and TK_LIBRARY are environment variables which are typically set on a Windows machine via Control Panel>System>Advanced>Environment Variables.
For TCL_LIBRARY
C:\Program Files\Ansys Inc\V80\CommonFiles\TCL\lib\tcl8.4
For TK_LIBRARY
C:\Program Files\Ansys Inc\V80\CommonFiles\TCL\lib\tk8.4
Doing this, you should solve your problema and Ansys will start normally !
Hoping it will be useful !
Alain
