disable assembly cuts
Hi All,
Is there a config.pro setting that will disable the assembly cut function?
Is there a config.pro setting to disable the assembly create a part in the assembly mode?
Tofflemire
Tofflemire
RE: disable assembly cuts
http://www.proesite.com/newframe.htm?/UTIL/
I did a search but couldn't find anything.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Thanks, I was already in that site.
PS I like you signature line
Tofflemire
This gives the External Referece Control settings, and if you set each tab to the bottom settings i.e. objects to None, geometry to Published Geom only etc. this effectively prevents assembly feature creation, because you can't select any references. There are config settings which control this also under ref_scope comp_scope etc, but I'm not sure what they are.
Hope this helps
Thank you I found it. default_geom_scope set to "pg_only" and the help of web site mentioned above.
Thanks to both of you.
Tofflemire
