Catching errors
Catching errors
Catching errors
Hi! I need help!
How to catch an error in Visual Basic for Word2000? Is there any constructions like Try...Catch...Finally?
P.S. I need to find out whether the file exist.
RE: Catching errors
Hi TyP,
A couple of options, under the Tools->Options pull-down, under the General tab, in the section marked Error Trapping, you can set it to Break on All Errors, or you can create your own error trapping with an:
CODE
On Error GoTo errHandler
errHandler:
HTH
Todd
RE: Catching errors
Don't forget to put an Exit Sub above the errHandler: or you'll run the errHandler every time at the end of your procedure.
Cheers,
Joerd
RE: Catching errors
2 TCARPENTER1 & joerd:
Thank you so much! I have done it! And it works (:
