insulating oil
insulating oil
insulating oil
is it possible to mix different transformer oil? what would be the risk to the equipment in terms of cooling effect, dielectric strenght, temperature rise,etc as per ASTM evaluation?
thanks..
RE: insulating oil
As long as the oil base chemistries match you should be fine.  Take a small sample and make sure that they mix OK and then check dielectric.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
