Change order of notes in title blocks
I have a standard title block that we use. In the title block are notes that are set up as user input type. The problem is that the order that the info is entered jumps all over the place. My question is is how do i change the order that the info is entered. I am using inventor 10.
RE: Change order of notes in title blocks
The only way that I know how to change the order of title block fields is to just move them around so that they are in the locations you want in the order that you want and then change the attributes to match. Kinda cludgy but it's the only way I know. Just a bit of advice though, be sure to change your template as well because you will have to change all of the existing file manually and you don't want to have to do that to any new files that are created.
Download addin "iProp Wizard" from sdotson.com and
you will be quit free in inputs order and fill in
preset values and so on. Many thans to Sean Dotson
once again.
