nitride heat treating
Does nitride heat treating of threaded columns of 4340 in tension improve the fatique life of the high stresses of the root diameter of the threads.
RE: nitride heat treating
as a student of materials I have never heard of cryogenically treating metals to increase their fatigue strength, what is the mechanism and does it only apply to 4340 range?. Can you point me to any other resources on the web?.
thanks
Gary
the theory behind cryogenic treatment is to finish off any martenisitic transformations that were not completed. Any retained austenite cuases localized stress due to its volumetric difference to martensite (approx 2%). By finishing off the transformation the internall stress are effectively relieved. Most heat treatable ferrous materials will benefit from this treatment but is generally only perfromed on high stress components.
Gaz.
Since I am not sure of the etiquette of posting web addresses on this site, if you will email me at info@metal-wear.com, I can point you in the right direction. Also you can do a search on the web for the Cryogenic Society of America.
for examples of good & not so good
