Need help on finding a substance
I am a mechanical engineer working on a manufacturing project and need helps in chemistry. I am trying to identify a substance that will reflect the invisible spectrum of light but not the visible spectrum. The substance shall be in a thick liquid state in room temperature. Could anyone help or point me to the right direction. Many thanks.
RE: Need help on finding a substance
TTFN
PS which invisible part of the spectrum: IR or UV?
It is the IR.
How much IR reflectance do you need?
Mirror-like or sufficient to detect the surface?
And for the non-reflected visible light: Do you want that absorbed or transmitted, or doesn't it matter?
Don't forget, there may an other way to skin your can....
Plesae read FAQ240-1032
WEB: <http://geocities.com/nbucska/>
