need catalog from this co.
This is a bit off topic, but I need a catalog or web site from a company that makes all kinds of bolt plates, brackets, shafts, studs, etc. You can select from charts in their catalog size of plate, number and placement of holes. They have really fast service and are very inexpensive. We don't have this here where I work now but in the past it was a required book. I only recall that one was dark maroon and the other was either green or tan. It may be something like M & L tool or something like that. I search the net but couldn't find it.
If a reply is posted here I'll catch it.
thanks
thanks
RE: need catalog from this co.
http:/
thanks
www.mcmaster.com
Wes C.
When they broke open molecules, they found they were only stuffed with atoms. But when they broke open atoms, they found them stuffed with explosions...
https://reidecom.reidtool.com/xephr/qbe/homepage
Web site is www.carrlane.com
good luck
http://www.masterlinedesigninc.com/
If not, any other hints? Location?
ERT
thanks again.
99 Dodge CTD dually.
