Insert an existing file as an OLE object
Inserting a PDF into our titleblock regardless of the check box that says display as icon the PDF will only be a icon in the titleblock. On some systems it will work correctly and on others it will only display as an icon. Am I missing a setting somewhere?
Scorch
SWX 2006 sp3.4
Win2000
980XGL
Scorch
SWX 2006 sp3.4
Win2000
980XGL
Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats.
--Howard Aiken, IBM engineer
RE: Insert an existing file as an OLE object
Do a search for insert object or insert picture or insert logo.
In some cases there appears to be no rhyme nor reason why some systems will not do this. For the record, I have never been able to do this & I have tried every solution offered in these threads. Some people have never had a problem.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
