Animate exploded view for use on a Web Site
Is there a way to use the animated exploded view simulation and have it saved as a file that can be used on a web site? If not is there any ideas on the easiest way to do so?
RE: Animate exploded view for use on a Web Site
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Otherwise, I think eDrawings saved as HTML format is certainly the simplest.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Yes you can use it in SW06. I just wanted to show in a powerpoint presentation where every part goes in to the assembly. Animate Expand/Collapse is really cool for presentations.
Nodal
You can even have screws rotate out and disappear on the way toward the edge of the view--very cool combos of things you can do, as well as using the point-of-view camera.
Jeff Mowry
