Moving sketch entities between sketches
I really haven't spent much time trying this but is it possible to take geometry that was created in one sketch and move it to another sketch?
RE: Moving sketch entities between sketches
ctrl-X
ctrl-V
You could save it as a Sketch block and import it into the new sketch as well
I didn't think it would be as simple as that, thanks.
You can also make a derived sketch and then "underive" it so that you can make changes.
For complex sketches with many entities, it's generally faster than cut-paste through the Windows clipboard.
How much do YOU owe?
http://www.brillig.com/debt_clock/
also, create a new sketch then drag (or ctrl-drag) the old sketch from the feature tree to the new sketch.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
