Urgent Need: Steam shutoff valve help!
I am having issues with my 2-way shutoff valves. I have installed Asco type 2-way valves, NC, 110VAC, Cv=5, 5psi DP, orifice size = 3/4", 3/4" NPT.
I thought that with these valves having a good Cv, and minimum DP, they would work great. However, now we have restricted flow through our Jordan type control valves (which are immediately downstream). We have gone from 25% OPEN on the valves to 100% OPEN, and still not getting enough.
Is this possible? I am wondering if we should have the NO valves instead (electrical engineer made a mistake).
Thoughts?
Thoughts?
RE: Urgent Need: Steam shutoff valve help!
Any other information that you know?
Cv of the Jordan valves?
StoneCold
