Running Pro/E locally / remote location
Is it possible to run Pro/E "easily" from a machine that is not connected to a network 100 percent of the time. I travel and would like to be able to do some work on the road. My company has a seat allocated for me so I can switch from Acad, but it seems like every possible obstacle keeps preventing me from making the switch.
Steve
Steve
RE: Running Pro/E locally / remote location
Although, a representative of Rand Worldwide just told me that PTC is breaking the Windchill product into smaller, easier to implement chunks, which might be the ticket for you. That way, you wouldn't have to implement Windchill in it's entirety (which is mega $$).
Recneps
You would want to put the license and server on your laptop. Then you could setup your desktop at work to look for the laptop as the license server. (When the laptop is on the network.)
Also you could use VPN to access your network if the license server is allready on the network.
let us know what works for you.
Proepro
VPN is an alternative, but depending on your current setup, may not be feasible. VPN will get a network license easily, but if your data must be checked in/out for data control (PDM) reasons, I doubt that you will want to wait while entire assemblies, parts and drawings are downloaded to a laptop just to make a few changes (then you have to upload everything when finished). Any VPN solution has to be COMPLETELY supported by your IT department, otherwise you will not be given enough access to VPN in the first place (whether you VPN using a modem or via internet).
If either of these solutions are not feasible, you should just wait until you are in the office to do your ProE work or have the company purchase a locked license specifically for you and your laptop.
Recneps
