Convection heating a hottub
Dear Participants,
I would like to use an open wood fire to heat a hot tub in the outdoors. I plan on making an open system, letting the water flow from the bottom of the tub through a radiator network within the fire, to outlets on the top of the tub using convection. I would like to control the desired temperature in a way that would use of as little energy as possible and was thinking of a solenoid valve that would disconnect this simple pipe network when the optimal temperature was reached, and engage a network of passive radiators to dissipate the heat before that water entered the tub. I can easily build the electronic circuit, but was wondering if there are some concerns about the design? (ie. will the patrons be scorched by boiling water if they sat too close to the hot outlets?)
Frazer RM Ross
Frazer RM Ross
RE: Convection heating a hottub
They'll be scalded.
TTFN
I would use a pump.
Don't forget that water expands when heated, and if heated enough, turns to steam.
Most people can only withstand 120F degrees for a very short time (threshold of pain). You need to control (limit) the heat input or mix cold water with heated water, so as to not exceed that threshold temperature. What will a pump do alone? You need to assure that the entering water temperature does not scald you or your guests.
You should not tackle this on your own without further invesigation, at this time you seem to lack the know how to complete a safe working system. Think it out and ask more questions.
Hey! what the heck! just buy a commercial hot tub. You may end up with less medical bills.
Good Luck
Best regards
pennpoint
I would hope NO medical bills if this was a commercially produced hot tub.
Thank you all for your suggestions and criticism.
I conceed your point regarding the medical!
There are wood fired hottubs which you can built or purchase however one has to be very careful not load the fire box with too much tender.
An online search will rinder many hits.
I do wish you well
Best regards
pennpoint
Happy cooking
StoneCold
Since this has been proven to work over history, and there is no pump involved with these systems, the only thing I would like to change is the temperature control. Instead of changing the temperature of the heat source, I would like to remove the heat in the water before it enters into the tub. I will do this via a radiator with a fan. There is much concern about boiling water & steam, which can be buffered by an open tank beside the tub (20 liters or so). This will alleviate the problem of steam. If the water is +120 I can have a temperature sensor within the buffer tank to sound an alarm.
Temperature can be measured inside the tub to control the fan on the rad. The only need for a power source would be the electronics and the fan which could easily be powered by a car battery for a couple days (given 4 hours of use a day).
The heating coil will be a 1 ½ “ pipe curved in a U-shape, (one pass in, one pass back) with a higher exit point for the “hot” and lower entrance for the “cold”. I plan on using garden hose, or depending on recommendations, fire hose to connect the heating coil to the rest of the system. The smaller the tubing and more surface area, the quicker the heat will transfer to the water and hence – steam – right?
The hot water inlets to the tub will be around ½ down the gross water level to allow for fluctuation (and I do understand that there will be a boiling problem if the water drops below these inlets).
The pump I am considering, but would rather not use because of the large consumption of electricity.
http://www.break.com/index/bb717.html
