Part file always opens when assembly is opened
We have a particular part file that is used in one subassembly. This subassembly is used in many larger assemblies. Every time we open any of the larger assemblies – which is quite often – this one part file opens in the background. I don’t want it to open however. It's the only part that opens.
Does anyone know of a setting in the part or maybe in the subassembly I may have accidentally checked that would cause this to happen? I guess it could conceivably be in our document management system, Conisio, which no one here probably has or can comment on, but I’m pretty sure it’s something within SolidWorks causing it to happen.
Thanks for any ideas.
SW2006 sp3.0
SW2006 sp3.0
RE: Part file always opens when assembly is opened
Adam
Solidworks 2005 SP01.1
Windows 2000
I recommend the Prompt option so that you are informed when a file is being referenced.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
As you may or may not see though in my terrible image I have that same option set at NEVER.
Adam
Windows 2000
I still wanted to find the root cause of the problem so I switched that option back to CHANGED ONLY, opened the file and subassembly and re-saved everything, and I doubled checked all references. It was still opening when I opened the sub-assembly. I then tried a ctrl-Q forced rebuild on the part and sub-assembly and it appears to have fixed the issue.
Thanks for the help.
Windows 2000
P4 2.40 GHz
Video Card -
Manufacturer: NVIDIA Corporation
Card: Quadro4 900 XGL/PCI/SSE2
Driver: 6.14.10.7184
