Need some info
Need some info
Hello guys,
Can anybody help me with some nice articles on transmission line antennas (leaky) or any info related to those.
thanks
thanks
RE: Need some info
www.google.com/search?q=leaky+coaxial+cable+.pdf
(Adding '.pdf' to your Google search often improves the quality of the results.)
RE: Need some info
I am trying to find some info on Microstrip transmission line antenna. From what I know we can control characteristic impedance of transmission line by changing thickness of dielctric substrate and width of conductor trace.
If I am trying to design microstrip transmission line antenna, what is the ideal characteris impedance Iam looking for? do I need to adjust it to 50 ohms because transmitter output is 50 ohms or anything is fine aslongas I terminate this line with charactesitic imedance?
If you need frequency information just take any UHF frequency. I am trying to understand this whole thing nothing particular in frequency.
thanks
RE: Need some info
In general, yes.
"...or anything is fine as long as I terminate this line with charactesitic imedance?"
In general, no.
RE: Need some info
RE: Need some info
I am also trying to findout more about txline antenna, can you send me some info.
thanks
