NX2 export moving absolute postion problem
I have a reoccuring and repeatable problem exporting iges/step/part files. It will end up in a random spot if I haven't closed and restarted UG in the last hour or so. Once I do it works like it should. If this isn't a problem with the software , then what hardware could cause this. I'm leaning towards ram, but I thought I'd ask if anyone else on this forum has had a similar problem.
RE: NX2 export moving absolute postion problem
Check the UG internal BBS.
I think this is a known problem in NX2.
Ben Loosli
Sr IS Technologist
L-3 Communications
