Math Software for pressure vessel calculations
I am looking into purchasing some math software to do a variety of things for pressure vessel design. One of the things I will need is symbolic integration (not as good at integrating as I used to be), where I am able to set up the integral but i am not able to solve it. Another thing I would like, if it exists, is the ability to solve volumes of intersections of two shapes. The canidates are maple, mathematica, and mathcad. So far the mathcad looks the most promising since the syntax is easy. I am not looking at pressure vessel software, this is to supplement that. If anyone has any experience with these packages, please comment on them.
RE: Math Software for pressure vessel calculations
ASME SECTION 1, I still use mathcad.
Otherwise CODEWARE COMPRESS: ASME DIV. 1, ASME DIV. 2, EXCHANGER ASME PART UHX. RE:(BECHTEL GOBLE STANDARD)
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
