SILVER PLATING BUSBARS
CAN ANYONE TELL ME A METHOD FOR SILVER ELECTROPLATING COPPER BUSBARS, I NEED A CHEMICAL PROCESS, NOT AN ELECTROLYTICAL ONE.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: SILVER PLATING BUSBARS
"Silver or nickel plating. This type of plating is being used increasingly where equipment is manufactured to american standards which require plated joints for high temperature operation. Nickelplating provides a harder surface than silver and may therefore be preferable. .... There is also some doubt as to the stability of these joints under prolonged high temperature cycling. Very high contact resistance can be developed some time after jointing. .."
cited from: Copper for Busbars, Copper Development AssoCiation (UK), 1996, p.40
I'd like to invite others to report their experience with the plating of contact surfaces in general and with cool-amp.
http://es.epa.gov/business/phase.ht
"Elimination of Hazardous Waste Via Advanced Composite Dry Plating System"
