Wrought Iron Bridge Tie Bars
I am examining wrought iron road bridge components. The tie rods (joining top and bottom timber chords) have been upset forged at the threaded end to increase the thread root diameter above the shank diameter. Was this standard practice 120 years ago? Was it for fatigue resistance? I assume this would have been empirically worked out as little was known about fatigue in those days.
The bridge authority must replace some of the rods (due to corrosion) and are considering rolled threads and other measures to cater for heavier and numerically greater loads.
On trying to come up with numerical values for fatigue improvement for this design of fastener and for fasteners with radiused guide surfaces, rolled threads, etc., the lack of design information for fatigue resistance becomes obvious.
Can anyone help with some references?
RE: Wrought Iron Bridge Tie Bars
Regarding fatique, one of the texts I have... "A Practical Treatise on Bridge Construction, being a Text Book..." by T. Claxton Fidler, M.Inst.C.E., 1887... debates if failure by fatigue is possible and that it might be some type of dynamic response to a moving load...
Dik
Here are several references on bridge construction using wrought iron and some discussion on fatigue
Hearing:
h
Paper on Structurals
htt
History of fatigue:
http:/
I have spoken to Structural Engineers about this issue but the Standards and Codes of Practice (South African, Australian - do not know about US) do not address design of fasteners to prevent fatigue failure. There are a few very old references on the subject.
http://w
and a some general information
http://ww
www.SlideRuleEra.net
