stress decay distance for seal groove
I have a thick wall, steel shell (cylinder) with two internal seal grooves.  These grooves are stress risers. Now the literature specifies a stress decay distance of k x square root of (R x t) for various types of discontinuities.  The value of k used varies from Pi/2 to Pi/4 to 1.0 to 0.5 and sometimes 1.1.  How does one select the appropriate value for k ?  I presume that it depends on the type of stress, but so far, I haven't been able to see a pattern.  Can anyone help with this?
Best regards,
         Downeast Tech
DowneastTech
Mechanical Engineer
Magnus R & D, Cypress, TX
RE: stress decay distance for seal groove
The problem with the literature is that it never has exactly your case.
If you need to know, you gotta test it.
or model it.
Cheers
Greg Locock
...or model it.  Except that I wouldn't trust an unverified model, so you've got to test anyway.
p.s. if you have 2 O-ring grooves, be sure to vent in between so you don't get a "pressure trap" from thermal expansion etc.
Oddly, I would, in this case since I see no practical way of correlating in detail, other than to compare the k from the book with the k from the model.
I'm assuming this is a fatigue problem, not statics.
Cheers
Greg Locock
Who are you using for a reference?
Peterson?
