MEASUREMENT OF DIESEL BLOW-BY GASES
We have been asked by a client to add some instrumentation to an engine test rig to measure 'crankcase blow-by' in order to assess cylinder wear, ring condition etc.
The client has only asked for a measurement of pressure, but in a vented crankcase this is likely to be so near atmospheric as to be immeasurable. I believe that what is needed is a measure of volumetric flow, ie the rate at which gas leaks past the pistons.
I have no idea what is a reasonable figure for a good engine, or what you might expect from a seriously worn one. The manufacturers seem to think zero is a good figure - I'm sure it is, but what is acceptable?
The engine is a turbocharged intercooled 20 litre V-12 diesel producing 900kW @ 2300 rpm.
Any guidance? Or experience of this type of testing?
RE: MEASUREMENT OF DIESEL BLOW-BY GASES
Many thanks for these useful numbers. I now have an approximate range to select an airflow meter. Point taken on temperature compensation - we can easily do this.
I still don't think that crankcase pressure tells us much unless the breather(s) are calibrated. A restrictive breather will give a substantial pressure but a large diameter hose will maintain the crankcase pretty much at atmospheric pressure.
I am not familiar with a turbo drain tube - does this normally vent significant quantities of compressed air into the crankcase? Why? Is this air which gets into the turbo lube system when turbo bearings are worn?
Many manufacturers, including Cummins, use crankcase pressure as the gage for TBO's.. A manometer is tycally the tool of choice..........
Tony
Tony Athens
http://www.sbmar.com
