Steam leak from casing split line causes
I know a few causes that might cause a steam leak from the casing split line, but I need all of them to better trouble shoot the problem. Can you help?
Causes:
1) Not achieving the right torque sequence when bolting.
2) The existance of steam cuts on the surface of the split line.
3) Un-even surface (hi spots) on the surface of the split line.
4) Using wrong torque value.
what else?
Causes:
what else?
RE: Steam leak from casing split line causes
