MathCADÆs solve for variable in the symbolic menu
I am currently working on a project where I am using MathCAD’s solve for variable in the symbolic menu. I have the following
First equation is ?m := 1/n3 where n3 is 11.408 this implies that ?m = 0.0877
I then try to solve for ? in the following equation using the solve for variable in the symbolic menu.
?m = (1/?)exp(-?-?) (For this equal sign I used Ctrl =) when I use the solve for variable I get ?=1/2ln(2/?m) which implies ?=1.564.
However, when I set the equation like this 0.0877 = (1/?)exp(-?-?) and solve for ? I get 1.14793 which is the answer I need.
Why are the two different? How can I get the equation to equal the 1.1479 when I use the variable ?m in the equation. I would eventually like to use the equation
Acm:=(1/?)exp(-?-?)=?m solve,?
Any help would be appreciated
Mark M
Mark M
RE: MathCADÆs solve for variable in the symbolic menu
I have a mathcad sheet if it will help.
First equation is Em := 1/n3 where n3 is 11.408 this implies that Em = 0.0877
I then try to solve for E in the following equation using the solve for variable in the symbolic menu.
Em = (1/E)exp(-E-E) (For this equal sign I used Ctrl =) when I use the solve for variable I get E=1/2ln(2/Em) which implies E=1.564.
However, when I set the equation like this 0.0877 = (1/E)exp(-E-E) and solve for E I get 1.14793 which is the answer I need.
Acm:=(1/E)exp(-E-E)=Em solve,E
so, if you back substitute E=1/2ln(2/Em) into (1/E)exp(-E-E)
does it make sense?
have you tried plotting the function out to see why there might be a problem?
Cheers
Greg Locock
