want to take picture
I have cgm file (having black background) & want to take picture of dwg but with white background. I tried to use command High quality image under view- visulization but when i shadow it i don't see anything.
RE: want to take picture
File, Export, (choice of gif, tiff, jpg, etc), click 'use white background', follow the bouncing ball... This will create a picture for attaching to an email, etc. If your taking a pic of the dwg sheet, any views added to the dwg that are shaded will NOT plot come through. If you need pics of a shaded model, then just do the above in modeling, not while viewing the dwg.
SS
CAD should pay for itself, shouldn't it?
For a drawing, I'd recommend plotting the drawing to file (which makes a .ps PostScript file) then open the .ps file with Ghostview and convert to PDF. Just make sure you're not plotting colors and everything should be black on a white background.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
