Impact Load on spindle
Hi, I am trying to simulate an impact load on a truck spindle. My model contains the spindle, the knuckle,two bearings (modelled as solid) and the brake disc. BCs are: an acceleration pulse in the center of the wheel and fixed boundary condition applied to the knuckle. The maximum measured acceleration in the knuckle is 20g (peak) and lasts 0.05 seconds. I am modelling the material as a Johnson Cook rate dependent material (isotropic law hardening and strain rate effects), although, plasticity will be small (physical test confirms that). I want to see what's the maximum stress caused by this impact, does anyone knows if I should consider dissipation effects caused by viscoelasticity? I am sorry for my english, I hope I was clear.
RE: Impact Load on spindle
Interpreting the results is likely to cause bigger problems than some weird energy absorption model.
Here's a justification. Your event has a bandwidth of 20 Hz. The modal behaviour of the spindle etc is likely to start at around 100 Hz (at least, 300 would be a reasonable target on a car).
However if you are worried about the nylon liner in the ball joints then you may be on to something. I'd still ignore it.
Cheers
Greg Locock
What would occur if the excitation bandwith was in the range of the natural frequencies? Would this add a stronger viscoelastic effect?
Since the objective of this simulation is to determine the maximum stresses generated by this event. What kind of simulation would you recommend for that kind of problems?
Thanks very much for your help... :D
Polaco
(Mechanical Engineer, 27 years old, Buenos Aires, Argentina)
Having said that, why not try a shorter event and see if these peculiar refinements make any difference to the stresses, my guess is that they will have a small effect only.
Most of the damping in practice will come from the interfaces nad other components, not the internal damping of the knuckle.
Cheers
Greg Locock
I will let you know about the results.
Thanks a lot for this help.
Polaco
