ANSI 14 TOOTH 12/24 B92.1 SPLINE SHAFT
IM TRYING TO LOCATE A SPLINE SHAFT DETAILED DRAWING IN ANY FORMAT OF A ANSI 14 TOOTH 12/24 B92.1 SPLINE SHAFT. COULD ANYONE HELP ME WITH THIS PLEASE. MANY THANKS.
RE: ANSI 14 TOOTH 12/24 B92.1 SPLINE SHAFT
Both Machineries HDBK and ANSI B92.1 will give you all the data you need to call out a Spline.  Sometimes I model splines if time permits and the rest of the times I just call the data out in a table.  Again, both specs will give you the information you need.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
