PROBLEM INSERTING BITMAP PICTURE IN A TITLE BLOCK
I inserted a bitmap picture in a title block (for the logo of my society) and, one day, i renamed by mistake this picture. Since, the quality of the image is very bad (the size of this logo is normally 260kb but when i insert it in my title block it looks like it is only 10kb or so). I have tried to delete this picture and to create a new one but i could not solve this problem. I tried with different bitmap pictures but same problem every time.
I have tried to repair autodesk inventor with the installation CD but no results.
Could someone help me??
RE: PROBLEM INSERTING BITMAP PICTURE IN A TITLE BLOCK
Inventor somtimes goes wobbly if you use a file that is not a true bitmap.
Open the file with MS Paint and then save it as a true 24Bit bitmap...
It might work, it might not, but it's worth a try.
