Can I make an equation betwen a part dimension and the distance betwen
Can I make an equation betwen a part dimension and the distance betwen another 2 parts in an assambly? How?
RE: Can I make an equation betwen a part dimension and the distance betwen
I think you can make it by this way. Within part environments check export of parameters you interest in(table of parameters-"fx").In assembly use derived part and check parameters only. Do it as many times as you have parts in equation.
In the table of parametrs (assembly) you will find part parameters and make your equation for value of certain constrain(s).
