Solidworks Camera Mode
Does anyone know if you can transfer an animation from a sub assembly into the main assembly? I used the camera function inside SW to create a animated sequence, this is stored inside the sub-assebly. I was hoping to use this same animation inside the main assembly.
Woolly
