milling radii
milling radii
i am trying to locate an OLD formula for milling a radius. this method allows, for example, a 2.5" radius to be milled using a 3" diameter milling cutter by tilting the vertical head to a prescribed angle and utilizing the milling cutter like a fly cutter.
this same technique is sometimes used on radial arm saws to cut a radius for making molding.
i had this written down many years ago and have misplaced it. i know this isn't a very accurate or precise method but it eliminates the need for a variety of cutters to mill shallow radius using a toolromm type milling machine. such a radius is needed for a bronze shaft rest pad on long leadscrews.
thanks in advance for the help,
bcreely
bcreely
RE: milling radii
RE: milling radii
RE: milling radii
RE: milling radii
RE: milling radii
RE: milling radii
i came out of an old us steel facility that still made their own gear cutters and hobs from scratch in the late 50's, never bought anything.
RE: milling radii
I am try to mill , 1/2 cylinder concave shape. 8" X 1.6" and the Radius is 1.62".
I don't have CNC nor I know how to use CNC ( newbie here ), only have sherline milling machine.
any tip would be greatly appreciate.
RE: milling radii
RE: milling radii
RE: milling radii
But (I hope) I'm not too proud to know my limits, and those chaps with the fingers missing are the guys I turn to first when I get stuck. And they help out a lot, once they've finished trying to get me to go and get a sky hook....
RE: milling radii
ok.. how and what do u mean by "shimming up"??
as for Sherline Milling machine, the arbor are about 1 3/4" long :(, and i can not find exact 1.6" radius cutter.
RE: milling radii
