New API 650 Seismic
New API 650 Seismic
I understand that the up-coming edition of API 650 has a completely re-written appendix E (seismic). Does anyone out there know how the new results will compare (higher or lower) to the old results?
RE: New API 650 Seismic
Steve Braune
Tank Industry Consultants
www.tankindustry.com
RE API 650 has a completely re-written appendix E (seismic) is a draft for review available.
A new API-650 is being drafted, but it is still an internal document for API subcommittee activities only. A public copy is not available.
Steve Braune
htt
There is a line near the bottom that reads:
PIP/API 650 Draft 79, dated October 5, 2005
It is not underlined as a link, but if you click on it, it will offer you the option to download the code.
Keep in mind this is a draft document and should not be used for design purposes until it is published.
Hope this helps.
