stainless fastening
stainless fastening
What is best option to fasten 3mm stainless U pins to 5mm stainless support plate?
RE: stainless fastening
Which end of the U pin is to be attached?
What are the loads to be imposed on the joint?
What are the materials?
new product now hundreds could climb to thousands,
both ends of U pin are attached to support plate, i.e U pin forms bracket,
joint loading is 2 to 4 pounds
materials 304 stainless steel, application temp 250C (482F)
From the back side:
I think that MIG Spot Welding is the best approach for the small numbers. The plate thickness of 5 mm may necessitate two small through plate holes, essentially a plug weld. The holes and weld would be small due to the load requirements. This would be an autogenous weld.
This could possibly be accomplished in a normal spot welder with a little set up.
From the front side:
I have also seen this accomplished with a stud welder(arc) with a special head.
MIG Spot Welding
http:
How much distortion can you have in the plate?
Does the plate have any other holes in it?
