TIP of the day: Possible cause of crashes
You have a user who complains about random crashes alot and there is no explanation as to a cause. Try checking the system time on the network server and the user's computer. If there is a big difference (more than 40seconds) you may have found your problem.
Checking time difference between two XP systems or an XP system and Linux with an NTP server running:
For target substitute the IP address of the computer on the network you want to check differences with.
For n put in 3 or 5.
http://tec hnet2.micr osoft.com/ WindowsSer ver/en/Lib rary/35731 215-0ec8-4 54d-89ba-0 f29f2469e3 61033.mspx
CODE
w32tm /stripchart /computer:target /samples:n/dataonly
http://tec
RE: TIP of the day: Possible cause of crashes
on your workstation double click the clock, click on the 'time ' tab, check the box to enable time server sync, enter the IP of your server and kick the admin if he did not enable an NTP server on your workgroup/domain server.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
CODE
at
More documentation is available at:
MicroSoft
www.engtran.com
www.niswug.org
