Through curve mesh question - NX4
Just got NX4 installed - looks good.
Just one question - How do I add a primary or sectional curve
to a through curve mesh?
RE: Through curve mesh question - NX4
You may now have to use Edit with Rollback to do this. You'll just have to try both Edit Feature and Edit with Rollback and see which one works. I'm typing this from memory, so I'm not positive this is the exact method, but it should get you to where you want to go.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
you do not have an option to add string. You have to select
the string you want to add , and then re-order it accordingly.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
