How do I find out the maximum thickness in a model
I am creating a part by limiting it between two surfaces. Is there any tool that may help me find out the maximum and minimum material thickness of the part?
RE: How do I find out the maximum thickness in a model
As Jack said Measure between is one solution, it is available with FSS or FSO licences in FreeStyle Workbench.
Check Online Doc.
Hard to explain, and probably harder to visualize - but I could never (and still cannot) get the "maximum distance" feature to work properly in V5. It's one of the top 10 things that I miss from V4.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
