Macro to count number of specific type of hole?
I'm hoping that one of you could tell me that this would work...
I need to be able to count the number of instances of a specific type of hole in an assembly (in the assembly's parts).
I can use a specific name in the FeatureManager for that hole type (i.e. DOWEL HOLE) if that would help the macro to find it.
Instances of that hole feature could have several locations (i.e. more than one hole per feature).
Could it work--a macro to traverse through the parts and count all holes named "DOWEL HOLE" (or some other identification method)? Please let me know what you think. Thanks!
Brian
Brian
RE: Macro to count number of specific type of hole?
Ken
There is an example in the SW API Help in SW that will traverse all features in a part. Then all you have to do is pick the names that match.
www.engtran.com
www.niswug.org
"If" you already know the Feature Names, you won't have to Traverse the Tree. But I'd guess you'll need to incorporate Traversing the Tree before you're all said and done with this.
Ken
