Find out where the max/min is
Hello everybody,
I have a simple problem which I cannot solve... Example: I have on column A the position number (1,2,3, ...) and on column B different values (measurement values). I can very easy put in a cell the maximal (or minimal) value of my B column using the "max" ("min") function, but how can I put near that cell another one with the position number where this maximal (minimal) value is? And, if possible, without using macros...
Thank you in advance for your answers!
Donnis
Donnis
RE: Find out where the max/min is
=+vlookup(max(A1:A5),A1:B5,2,FALSE)
Alternatively, you could leave A and B as is, put a duplicate copy your position numbers out into column AA, and use
=+vlookup(max(B1:B5),B1:AA5,26,FALSE)
That's a little cumbesome and assumes you don't have any data out there. I don't really like extra hidden columns because it's easy to forget about them when you change your data.
Maybe there are some other ways?
