uns n80904 & forgins
This is my first thread. Hi to everybody.
My question:
I need a flange made in uns n08904 but I can't find it in asme sa-182.
What is the right specification for uns N80904 forgings?
Thank you.
I use:
SA-240 for plates
SB-366 for fittings
SB-673 for welded pipe
SB-677 for seamless vpipe & tubes
RE: uns n80904 & forgins
The UNS N08904 is 904L. You could machine the flange from plate; see below
ASTM B-625 or ASME SB-625
Also forgot, the obvious;
ASTM B-649 Gr 08904, which is a forging specification. This is cited from ASME B16.5-2003 "Pipe Flanges and Welded Fittings", Table 1-A
thank you.
I can't machine the flange from plate (client spec.)
I'll use SB-625 as you write.
I found the S80904 material for plates in SA-240 and in SB-625.
Which one shall I use?
 /// I'll use SB-625 as you write. ///
no sorry the i'll use SB-649 as you wrote !!!
