Roark's Formulas
Roark's Formulas
Roark's Formulas
Anyone please: What is Roark's Formulas for Stress and Strain. Where can it be obtained
RE: Roark's Formulas
Try Amazon or any bookstore with a technical/engineering section.  It is a very well known reference that has been around for years.  The older versions are by Roark and Young, but it seems like Young had already passed away when my 5th edition was published.  It is a real storehouse of design information.
I have a book given by an older engineer (retired now). Teng H. Hsu, Stress and Strain Data Handbook, 1986.
I never even opened it. Should I upgrade to Roark's?
if you never opened your first book, don't bother getting a second one ... you don't need it (unless you're trying to fill shelf space).
Roark's is good for calculating stresses and deflections in plates and shells, as well as torsion & other various types of loadings.  It has lots of tables with formulas for various loading and support conditions.  Its' published by McGraw Hill and the sixth edition (1989) author is Warren C. Young.  Raymond Jefferson Roark (1890-1966) is the original author.  I use it occasionally.  Its' worthwhile having.
Oops, got the wrong name for the deceased.
Roark's is unique, as far as I know, in it's wealth of plate and shell formulas. Bagman, your endorsement sounded only semi-enthusiastic, perhaps you know another source?
I got an electronic version of Roark and Young on eBay for $7. Best seven bucks I've ever spent.
It's got great information on stress analysis and what I consider to be indispensible info on plates. I have used the plate formulas in my work, too, so the book paid for itself.
I first came across R&Y in school nearly 20 years ago. It was an expensive book, so I put off buying it (it was often cited in the FEA classes I took). I found a 1940's edition for about $10 just a few years ago. But I snobbishly  thought "does this reflect anything Timoshenko did afterwards?" and I convinced myself not to buy that edition. Was I right? Doesn't matter...
I know of nothing better for calculating plate stresses.  I would like to see more end conditions for plates in Roark's though.
