What material for piling marina? electrolytic corrosion? pile strength
Hi, just found this forum and think it's great. Tons of interesting posts.
I am researching what is the best material to use for a pile in a merina? The marina pontoons will be supported by piles and at the moment the existing piles are a combination of rotting wooden poles, I-beams and mild steel poles sunk into drilled holes in the rock and back filled with concrete. One wooden pole is only a stump in concrete and needs replaced. The entrance to the marina is small so a pile driving barge is too large.
Regarding the strength of the pole. We require to drill out or otherwise remove rotting stump, insert new pole and refill with concrete. This needs to be done underwater. Or we could drill a number of holes into rock, make shuttering and fill with concrete with reinforced steel into holes and upstand pile in setting concrete. Any other ideas?
The material options for pole are mild steel coated, galvanised steel pole or stainless steel 316 pole. Surprisingly the SS pole is the cheapest and is one we are considering. Would this corrode quicker than a mild steel pole? Coating a mild steel pole is about 3 times the price of SS pole.
The pole needs to be 7 metres long and there is a rise and fall of tide of around 3.5 metres.
Also, side loading on pole (most at high tide) will be 2 boats windage. IS there a recommended formula for calculating windage in high winds?
We are also looking at the AC earthing on the pontoons. What is the recomended resistance to earth. We are hoping to get down to 2-5 ohms with around 10 copper earth spikes on shore as this has been a problem with the marina. IS using a SS pole going to provide an easy way to earth compared with a galvanised or coated steel pole?
RE: What material for piling marina? electrolytic corrosion? pile strength
Mike Halloran
Pembroke Pines, FL, USA
If you can drill large enough holes into the rocky seabed to set the poles/piles in place, you could then pump concrete or grout down the inside of the pile to force the water out and thus bond the pile into the rock.
http://www.cmilc.com/index.htm
ht
http://www.durablewoods.com
Marina problems with AC are usually caused by improperly wired boats. Reducing ground resistance to remote earth is unlikely to help anything.
AC earthing is something I'm qualified to answer. If further discussion in this area is required, I'd suggest the electric power engineering forum.
If metal is your choice i would not use S/S for any foundation or marine pile, the reasons are long and many but trust me S/S is not the pile.
You haven't indicated that cost is a big factor, so why not use a Ti alloy? Great strength/weight ratio and no corrosion concerns.
