Weird mesh on straigth sections...
Hi Pro/M lovers,
I experienced a weird problem with the automatic meshing of Pro/M. The model is a Z-shaped lever made with a rectangular rod, so the model (built on Pro/E) has 3 straigth sections and 2 fillets. The problem comes with the meshing operation: the mesher creates several nodes on the fillets, but nothing on the straigth sections, so these straigth bars have super-stretched elements since their nodes are on each end of the straigth section... I've never experienced such a problem before, so I'm wondering if I changed something in the settings, causing this problem to occur. The elements are tetrahedral.
Thanks.
Thanks.
RE: Weird mesh on straigth sections...
Thanks.
