Reverse/inverse a vector
Hello everybody, I have a question.
I would like to reverse a vector, I mean transform [1,2,3,4] into [4,3,2,1].
Do you know if there is any function that can do that?
I have to do with many vectors, so it could be tough to do a bucle with each vector.
Thank you
Thank you
RE: Reverse/inverse a vector
fliplr() for a row vector (or each row of a 2D array)
flipud() for a column vector (or each column of a 2D array)
x(end:-1:1) for the general case of a 1D vector (either row or column)
