Changing a dimensions driven properties
First off, this is my first post, but what a help you guys (and gals I presume) have been! Very helpful forum.
I am trying to figure out whether or not I can change a dimension from driven to driving through an equation? I have a situation where if a formula meets a certain criteria, I want one dimension to drive, otherwise let another dimension drive. Does that make sense?
SW2006 and working with Weldments.
Thanks for the help!
Joe
Joe
RE: Changing a dimensions driven properties
If I was to do it in excel, what is the text needed to change the driven property of a given dimension?
Joe
You can control dimension supression (driving/driven) per configuration. As MFDO suggests, you may be be able to control that from a design table as well.
I suggest placing an enhancement request if you're on subscription.
h
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP3.3 on WinXP SP2
